Everyone makes mistakes ! I've seen good mechanics pour new oil in the crankcase before screwing the drain plug back in only to have 2 quarts on the floor before noticing it when I worked @ a dealership.
But I got to tell you what I did once, a kinda Bonehead thing.
I seem to remember I was in a hurry that day, changed the oil & filter simple enough. I always run the truck & check for leaks, check oil pressure, it was fine.
Kept the truck running put the tools away then went for a ride. About 2 miles into my ride the truck's cab engulfed in smoke. Immediately I shut the engine off & parked . What the F ? blown engine, oil line, gasket ?.
ANYWAYS, all the oil comes pouring out the side of the engine but I couldnt tell excatly from where due to all the smoke from the oil spilling on the hot exhaust & engine. What a mess , big puddle of oil on the ground, smoke galore.
Called my brother & he came & towed me home.
After getting home I checked the filter, she was on tight, didnt forget that, then I removed the filter.
Hmmmmmmmmm 2 gaskets, Theyre were 2 oil filter gaskets on the F.ing thing with a crimp on them both where the oil blew through . When I changed the filter the old filters gasket stuck to the engine { I allways coat the gaskets with oil } but it somehow happened, & I didnt notice it.. When the truck reached a certain oil pressure & rpm into my trip it just blew out inbetween the gaskets...
Embarrassing, messy, but no damage to the engine & I was happy that it was a minor thing.
