Propflux01
$100 Site Donor 2025
Originally Posted By: The Critic
GM does not require brake fluid changes on DOT3 vehicles. Power steering fluid changes are not required either -- by most manufacturers.
Yes, changing DOT3 brake fluid may not be a bad idea - but it's definitely not required for every application. I am sure that GM came up with their recommendation after lots of testing and studying of the failure rates over the anticipated lifespan of the vehicle.
I've seen many 10-15 year old cars with the original hydraulics and the original fluid and they worked fine. In fact, they worked better than the ones where people had changed the fluid - as many brake fluid changes result in people letting some amount of air into the system.
And once you add the possibility of broken bleeder screws, complications with ABS and the additional time involvement - most beginner to moderately-skilled DIYers are better off leaving the system alone... if the OEM does not require brake fluid changes.
You would be surprised at how much braking efficiency is lost with 4-5 year old brake fluid. Regardless of whether GM requires it or not, it IS a fluid, it does absorb moisture, and it does break down. And we all know quite well about some of GM's decisions.
When I do full brakes on a car a fluid exchange is a requirement for me. I've seen the results of a fluid exchange many times.
