There should only be two batteries available for the 2013 Accord depending on which engine is came with (51R for the 4 cyl and 24F for the V6) so there should only be one set of battery-mounting parts for one or the other. Looking at this parts diagram, which is for a 2013 EX-L V6:
https://www.hondaautomotiveparts.co...as/electrical-exhaust-heater-fuel--battery-v6
I used parts #2 through #6 and two #17 nuts. The nuts can be re-used if you don't want to buy new ones as they are the same parts as the originals.
As I mentioned in post 11, if I did it again I wouldn't bother with the battery cover (#6) which will save you a few bucks.
Yes, you can do it cheaper by creatively hacking some of the bits and pieces but $40 for some OEM parts makes it fit like a glove and look like it came from the factory with a 24F.
