I ask a question on other thread but got no answer .
I did a pan drop and filter change on 2010 F150 5.4l platium 6R80 6 speed automatic .
I change while the truck was stone cold ( been park for 2 day ) . After drain out . I measure about 7.5 qt . Put back in 5 qt and it start to drip out the fill hole . I went and start the truck . Check the fluid and it was empty . So I add little by little and keep changing the gear from park to 1 and back to park .
keep adding the fluid . About 20 minute later it come up to hot mark . It’s like took 9 qt to get it there . Take out for 15-20 city and freeway mix drive . Shift better then before .
Anyway when I got home . When and check the fluid . It’s way way above the cross mark .
Did I over fill it ? Anyone know a easy way to check the fluid on these 6r80 . I did almost burn myself couple time . Even with mechanic glove on .
quick note : after take out for a 20 min drive . After come home I check right away .is that why it show my fluid is way too full . Should I wait few min for the fluid to settle down .
