Recently changed the trans filter and replaced what transmission fluid that was in the pan from my 05 G35 sedan 116k miles. About 4 qts. It turns out I used the wrong trans fluid.
I used castrol transmax CTV instead of castrol transmax for imports. I dumped the pan and refilled letting the fluid warm up and I checked and rechecked for a while. Everything seems ok. The car shifts fine but I'm wondering if I should I flush out more of the CVT? I know the manual states use only J matic fluid but read that transmax was a fine alternative.
