Did a piston soak on the 18 Kia 2.4L this weekend
My Scion burned over a quart in 300 miles when I bought it. A piston soak improved that to about 1000. A second soak with two full bottles of B12 improved it to the point where I don’t add any oil between changes.
B-12 is a very strong solvent. I absolutely am on board with piston soaks on engines that can do them (I can’t on my Boxers). But I don't think it’s wise for people who dump it in the sump and run the engine with it. There’s unnecessary risk using a strong solvent in measurable quantities IMO.
My personal use of B-12 would be a 24-48 hour soak with the plugs out and ignition disconnected with periodic addition of extra B12, and a few revolutions with plugs out every 12 hours. After 3-4 of these cycles adding B12 and cranking, I’d immediately drain & change the oil and filter, and then run a 3k OCI after that with a quart of EC. Then change oil and filter again and resume normal OCIs.
I wonder if some people do piston soaks as a preventative maintenance measure when doing their tune up? I'm still on factory spark plugs about to hit 150k miles, was thinking if its wise to knock 2 birds with one stone?
Run one side up on a ramp and do those two cylinders? I know you can’t fill it all the way up but capillary action will probably help it creep up to the top of the rings.
I won’t run it in the sump either.
I would. And I will, when I replace spark plugs. Also was thinking of Amsoil Power Foam, that way the upper cylinder area can get some cleaning too.
Nah, there’s no safe way to get the one side high enough to be useful without causing a safety risk from the angle needed or the probability of oil starvation IMO. Thankfully, EJs do not have any real history of oil ring problems unless the engine has been severely neglected; the biggest issue I’ve had on my EJs as they age is the VC gaskets and spark plug tube seals that “fail” due to shrinkage causing leaks.
It’s not an overly involved job, but simply due to how tight the strut towers are to the VCs I’ve just let my indie do the two EJ251s that had tube seal leaks. About $60 in OEM parts and 2 hours of labor at $55 per means for $170 there was no way I was donating blood and cussing all afternoon. 😂
Update
Oil level is still on full today! I added 1/4 quart late last week, but it’s been quite a while now and it’s still not using. I’m very happy!
Awesome, this inspires me to try it on a friend's car that I know is burning some oil (2013 KIA Rio).
I put some thought about this topic during lunch. I know there are many approaches to a problem and solution.
While my car doesn't currently burn any significant oil currently I'll keep this topic in mind for future references & friends that have oil burning issues.
Let me know if my step method of approach is sound? Its probably excessive for most here.
1. Car front wheels on ramps
2. Remove spark plugs
3. Turn crank until pistons are even depth
4. Fill each cylinder with around 4-6 oz of B12 or Top Engine Cleaner & cover spark plug holes
5. Wait 6 hours
6. Check for leak down
7. Turn engine crank
8. Top off with more B12 / Top Engine Cleaner, turn crank & cover spark plug holes
9. Wait another 6 hours or overnight.
10. Check for leak down & turn crank
11. Repeat step 8, 9 & 10 if desired
12. Check for leak down, drain/suck out remaining solvent in cylinders
13. Wait 6 hours or more until pistons are dry
14. Add small amounts of engine oil (1-2 oz) in spark plug holes & turn crank to lube cylinder walls
15. Suck out any remaining excess oil in cylinders
16. Install spark plugs and coils
17. Drain contaminated oil & filter
18. Fill new oil to crank case, new filter
19. (optional) Add fuel system cleaner (BG 44k / Techron) to gas tank (to accelerate oil wash off on pistons on car startup)
20. Drive for 500-1000 miles or until fuel with cleaner is exhausted
21. Drain oil or use engine flush (BG EPR) & Drain oil / filter
22. Fill new oil & filter.
23. Monitor oil consumption per x miles driven.
5. Wait 6 hours
Sounds good to me. I'd drive it easy for 10-15 miles then beat on it for a bit. On the Audi 2.0 I did after the flush and changing the oil and filter, I did 4-5 0-75 mph WOT hits. Some say run it down the road at 4000ish rpm for an extended period. I ran the car with 2 cans off Berryman's in the crank case in the driveway only. Mixed reviews on this, but it caused me no issues. The car did start to miss heavily after 3-4 minutes. I'm sure this was the Berryman's off-gassing. I pulled the plugs, oil filter, left the fill cap off and drained the crank case and let the car sit overnight. It ran perfectly the next day after adding new plugs and changing the oil, and has used little to no oil since. It was using a qt every 400 miles.
I had to add a 1/2 a quart today. The last time I added was on March 29th when I added 1/4 quart. Today I added 1/2 quart of the HPL EC30 that I had laying around from when I used it before.
Overall, I’m still very happy with how much this has helped slow down a major oil burn into something pretty minor. I will be doing another piston soak at the end of this OCI though. Especially since it helped so much. Not sure it will ever cure a bad Kia ring design though???
I suspect the GDI system forces a small amount of fuel passed the rings causing the cylinder walls to get scuffed which causes the oil burning. Just a theory. I don't think it's a stuck ring that can be fixed with a piston soak.
Do you think it's Kia's gdi design? Audi and other manufacturers use direct injection but don't see this issue.
The first soak on my Scion took me to around a quart every 1000 miles. The second one a year later essentially stopped it completely.
I have a 2017 Kia Sorento 2.4L GDI with 69K miles. The dealer did a piston soak 2 months ago which was unsuccessful. I thought I was going to get a new engine. Stopped by the dealer today and asked the status. KIA wanted them to do a second piston soak. They didn't let me know about their KIA message from about end of April. So I will take it in again Monday. The dealer rep said that the piston soak is usually not fixing the oil burn. After reading many comments here on piston soak, I think they are either not using an aggressive cleaner, or not repeating on adding cleaner like some here do. I am concerned that this oil crap is going to ruin my cat converter. Also..I am interested in seeing if my cylinder walls are scored. If I was a mechanic, I would check the walls with a borescope after removing the spark plugs. I had consistent 5k OCI.
My son has a 2014 Kia Rio with 150K on it. Tried all of this, and it didn't help (made it marginally worse in fact.) Issue I think on his car is carbon scoring on cylinder walls allowing oil to just blow right by.
I will say that I put Supertech 10W-40 semi-synthetic in his car Mothers Day weekend, and the level has hardly moved. Never ran a 40 weight in it before, but seems to be doing pretty good with it.
I ended up doing a second piston soak on hers at the last oil change. The oil usage was better than before, but still slowly creeping up. This time I put in VRP and we’ll see if that helps. I left town last Monday and checked before I left, still full. I’ll check again Saturday when I get home. I have high hopes for VRP keeping the rings free!!!
Just out of curiosity, what grade of oil are you using?
I saw the VRP video on YouTube. I am going to use it too I will stop by Walmart today and get some. I will use it on my Dodge Caravan for sure. I have to check to see if the dealer will put it in my Kia since it is NOT DEXOS. My plan is to put in BG EPR 109 right before I drop my car off at the dealer, have them do their 2nd piston soak and then fill it with VRP unless they reject. I usually give them KIRKLAND 5W-30 (Costco) oil ($30 for 10 qts-on sale) which is DEXOS. Before I wanted to give them PENNZ Ultra Platinum , but even that is not DEXOS. Glad to see you are getting success, I have had oil burn problem since before 50K on my KIA 2.4L and it is now at 69K
Why would a Kia require a Dexos rated oil?
