Are the improvements in the Dex III H fluids sufficient to allow it to be called a synth blend ATF or was the spec an improvement to the AW/EP additives?
I have one vehicle that can use OTC ATF fluid and will probably buy the jug of Pennz D3H from Wallys.
Many on this site seem to have a very good opinion of Pennz motor oils, does the same apply towards there ATF. I've seen posts recommending Chevron ATF, but it isn't available in any of the places I shop.
