Dex VI in heavy truck steering?
Toronto, Canada
TRW calls for TES389/TES295 fluid for their THP 60 steering box. Truck is a 2006 Freightliner M2
https://www.trwaftermarket.com/globalass...1-june-2016.pdf
I am currently using Mobil Multi Vehicle ATF
https://mobiloil.com/en/automatic-transmission-fluid/multi-vehicle-atf
It meets Dex III, which is what was originally specified for this box
Mobil Dex VI does not list TES389 as a spec it meets.
https://mobiloil.com/en/automatic-transmission-fluid/dexron-vi-atf
Can Dex VI be used? Is it any way superior to the Multi Vehicle ATF, which is also a synthetic blend? Is there an issue with viton seal compatibility?
Yes, I am well aware of that and that is what I use in Allison transmissions. My question was specifically about Dex VI. I was looking for less expensive alternatives to the Mobil Delvac 1 ATF since the power steering system is a less severe environment than an auto transmission. Is Dex VI better than the Mobil Multi Vehicle ATF that I am currently using?
You might get away with it in a TRW box (never use ATF in a Sheppard)...but I'd stick with the Delvac 1 ATF...it's not like you change it often or it's a big sump. IMO...Dex VI is too thin for a big steering box.
