Thanks for the link, Brio. Sure enough, it states "DEUTZ filters have a high relief valve pressure of 35 PSI, which allows the engine to run longer before filter changes." This is an aspect of bypass pressure theory I've never heard before. But it makes sense since it will continue to force oil through the media, over time, even as the filter gradually clogs. But of course, there's trade-offs to everything, and I can't help but think there might be one here as well, especially since the competition typically uses about half that much bypass pressure. Without knowing all the pros/cons of Deutz's philosophy, I do know that a safe route in extending oil drain intervals, if feasible for a given engine, would be to simply go with an oversize filter, rather than follow Deutz's 35 psi route. The stock Purolator filter for many Hondas, for example, is the 14459, while simply switching to the 24458 adds 50% more media, with no need to pump up the bypass pressure for equivalent results. One caveat is that it appears many German cars come OEM with high bypass settings (heard before and confirmed by Alan), and if so, then going 35 psi is a non-issue for those rides -- maybe they even prefer it.
Alan: I suspect that as long as you use a good quality filter and change it regularly, the bypass setting is of only limited significance since under normal circumstances (OTHER than cold start-ups, high RPMs, and throttle jabs), the bypass valve should be closed anyway in your non-clogged filter.
[ March 10, 2004, 07:55 PM: Message edited by: TC ]
