Originally Posted By: Garak
Originally Posted By: dustyroads
I don't have a grasp of ACEA specs either, other than E9 being similar to CJ-4. I know Garak is up on the ACEA testing. Are 5W40 oils superior to 10W30 oils in meeting their requirements (still talking HDEO)? Or maybe I should ask if 5W40 oils in general have more approvals over 10W30's?
There are others better with flow than I am; I am good at remembering specifications.
When it comes to fuel economy, you'd probably lose a bit during warmup with the 10w-30 over the 5w-40, but gain it back in the highway running, depending upon how far apart the HTHS is. It's really hard to nail the benefits down accurately outside a lab. However, you can be rest assured that a higher VI will help fuel economy during warmup, and a lower HTHS will help fuel economy during running. That is a big attraction for 10w-30 lubes, since they can gain you some fuel economy without blowing your lubricant budget out of the water, assuming you don't extend OCIs. As for starting, at your -10 F example, I'd want a 10w-30, at the minimum.
10w-30 lubricants can meet E7, E9, and Mobil Delvac Elite 10w-30 certainly does. How superior they are to meeting these specifications is anyone's guess; a formulator might know. ACEA specifications are self-certifying and most are pass/fail. I doubt that Imperial Oil would give me any results on one oil, let alone let me compare one of theirs to another, assuming both were certified.
You will tend to find more builder approvals on a 5w-40 than a 10w-30, at least if you look at the right ones, but you're not going to find a shortage of certifications when it comes to 5w-40, 5w-30, 10w-30, or 15w-40 HDEOs. And yes, a 5w-30 HDEO can do some amazing things. But, one has to extend the OCIs to make them worth it.
If you want to see some extended OCIs in trucking, look for Doug Hillary's threads in this section. He had OCIs roughly four times the length of what you just did.
Maybe he'll see this thread and give us a bit of a history lesson as to his experiences.
Thanks Garak. These days I mostly get oil changes on the road and as I mentioned before the syn blends are an extra $50 over a bulk 15W40, but T6 and either of the Delvac 1 oils add $150 to the base price. It's not insurmountable, just run it longer and it'll pay for itself. I just don't want to run that long yet, especially with the possibility of cam failure and a possible dispute in warranty claims.
