Originally Posted By: Verminator
Interesting thread. A couple of questions though...
1. What does WOT stand for? It's not in the acronym list, and yes I checked.
2. So it is fairly widely accepted that keeping the RPM's below 2,000 is preffered until the oil temp reaches 170F?
3. That the oil should stabilize around 200F once it's fully "at temperature"?
My car revs at about 2,300RPM on a cold start up right off the bat until it idles down slowly. This is just with the turn of they and NO gas. I've never liked this about my my car and have always felt it fires up at too high of an RPM, especially on cold winter starts. Once warmed up it idles around 900 RPM. The only way to reduce that start up auto-idle RPM of 2300 (that auto reduces over several minutes) is to put some load on the vehicle, even if that is to put it into gear and move slowly without any pressure on the gas, but I'm thinking that "load" is not desirable either correct? Thoughts on this?
I'm going to hook up my OBD2 canncer to it tomorrow morning and see how long mine takes to get to 170F after the cold start and see if I can keep it under 2,000 RPM until then..albeit my start up auto-idle flashes it up to 2300 RPM to start...
WOT stand for Wide Open Throttle.
You should not rev to redline until oil temp is more than 170F. I usually keep the rev below 2000 RPM for the first mile, up to 2500 RPM second miles, 3000 RPM third mile..
The Honda S2000 will stall with 5th and 6th gear at 2000 RPM, so that I add 500 RPM(2000 RPM in other cars 2500 for S2000) to it during cold start.
It depends on ambient temperature, oil temperature may not get to 200F when air temperature is -20F, when ambient temperature is north of 110F oil temp can be 220-230F or higher if you keep the engine running at 5-6k RPM.
