Dayco molded lower radiator hose poor quality
Paulo,
I had a senior moment. The hose was a Gates, not Dayco. My error in this thread. Sorry for the confusion.
No worries. I get senior moments ALL THE TIME. I should have read thru the previous posts or looked closer at the label on that hose.
The real common one is I'll have a wrench in my hand, I'll put it down and them I can't find it for 10 minutes (if at all). I have a pair of side cutters that I haven't seen in a long while.
I've never heard of a radiator hose failing on any modern car unless it was related to accident damage.
I don't know what constitutes modern but I just replaced a failed upper rad hose on a '99 XJ. Not sure if it was the original hose?
It failed at the inside radius of a relatively tight (molded) bend
  • Helpful
Reactions: GON
You must not keep vehicles very long. They do last a long time but eventually they degrade to the point requiring replacement.
Paulo, when I was putting on the Gates hose later at night, I lost my hose clamp pliers. How the heck could I lose a 30 inch tool while using it.
Look closely.
Sorry to hear that some of you have had bad luck with Dayco hoses. In October 2020, I replaced my heater core and decided to replace the lower radiator hose as well; Dayco 71806 for a 1998 Volvo S70...I had to replace my radiator in May 2023 and inspected the lower hose. Replacement radiator was Nissens. Once again, no worries from the Dayco hose; no bulges, cracks etc. As I recall I only paid $3.39 plus tax and shipping from RockAuto for a total of $14..
  • Like
Reactions: GON
I replaced the radiator and hoses on my Avalon a few months ago. I had a hard time getting hoses, twice I had orders canceled by local dealers for the OE parts. So, I bought a set of Gates hoses from Rock Auto. The bottom hose looked good, but the top was way off; the bends were right, but the length on either side were way off and the cuts looked like they were done with a shovel. I contacted Rock Auto and they sent a replacement without asking for me to return the problem one. The replacement fit perfectly. I am guessing that Gates is skimping on quality control.
when it comes to part you probably will change once in your life time i always get the pricier part. Not worth hassle for a few bucks.
