I have the time but not the tool. Yes, I am referring to the split boots and actually just found some online at Oreilly Auto. Luckily, the same boot fit my Honda as well so I ordered 3 since I think the driver side boot on the Corolla may be next.
I am aware that there is a chance for slow leak when extreme heat. This is where some automotive tape can be useful as an extra layer wrapped around. Duct tapes have been used to actually repaire the damage boots but since I tend to keep the vehicle much longer, I am going with a new boot. They only cost 27 dollars per boot kit.
I do plan to replace the entire axle assembly later on the line when when I can find a person or DIY shop that has the tool to assist me. I know it is an easy process but require very specialized tool, a lot of patient, and possibly a helping hand. I probably will do that along with getting a new strut at the same time. For now, I just need this fix the quickest and easiest way possible and the split boot is the answer. I do wish they make it where leak is not a problem though. It shouldn't be that hard to design something easy to work on. By the way, split boots cost much more than regular boot, which is actually a pain to install.
I am going to use duct tape to wrap the damage boot tomorrow. There is something to be said about doing your oil change frequently, I only found out about this during the oil change. If I waited until another thousand mile as for my usual OCI, I could be putting my vehicle in much more severe damage. For all I know, this could have been splitted for weeks or months. I am going to get some grease from Walmart to temporarily fill it in. There is no noise and the bearing is still very wet so there is no damage anywhere beside the boot.
Is there any cheap grease I can use temporarily? What about that grease in the spray can from SuperTech. It only needs to hold for about 1 week and possibly 2000 miles drive at low speed.
I am going to inspect my Honda tomorrow. I guess my week off will be spent partially fixing my car, cleaning up my apartment, and some road trip on Wednesday.
