Originally Posted By: steve20
Jim- isn't RP supposed to be purple?-
steve
Ha! You'd think... but the purple color was gone in less than a thousand miles and it from there looked more gold (a purply gold)until it got the way you see it at 7.5K.
I'm pretty sure I could have gone farther too, on both the oil and filter, but I'm taking it easy to feel out the oil in this engine. The UOA will tell the tale on the miles (I don't worry mch about the time from the engine standpoint). It took over a year to get to 7500 miles for me. If I didn't have so many other pieces of equipment to maintain, I'd probably go into oil change withdrawals. I have two more fills of RP 5W20 to trend and then we'll see. That's 3-4 years worth.
RE Filtering ability: That is one figure I have never seen for sure. It is a Purolator AFAIK, but which media... ??? I'd love to see the specs.
I put a Royal Purple filter on for this run, which may have better media than the MC, though I prefer the bypass valve up near the top, as the MC has, rather than at the bottom. Overall, I don't see that as a major sticking point because it's not likely to bypass with a 5W20 oil. I'll cut it up too at the appropriate time.
