Amsoil EaO80 with 13 months/27,600 miles on it. This came off my 2004 Dodge Ram Cummins. This was the fourth oil change using this oil change interval. No bypass on the truck either.
I had a guy with an older Cummins go 2 or 3 years with HD Amsoil 5w-30 with the Bypass, and the UOA was fine. He bought it from an older guy that forgot how long it was in the truck.
To answer oilboy123...the best "cutter" for cutting open an oil filter is a rotary tool (Dremel or something like that) that spins at a very high speed. This minimizes rough edges that would normally be caused by slower saws.
But it flings a bunch of metal fillings everywhere. Kinda makes it hard to look for filter contamination. The OP has a nifty oil filter cutter you can see in the pictures. I too would like to know where he got it.
It's not the best, but gets the job done.
I find that the filter wants to "walk" up as I turn it.
Also, it makes a very slight bend in at the cut point.....so you have to work the filter element out.
It does fine for me and I am happy with it.
Dremel tool would work, but it also requires some care in use to get a good cut.
I should have cut the media and laid it out. I looked in every pleat and there was nothing in it. I am using the Donaldson ELF7349 this go around since it is the same exact media.
The filter cutter I have is made by Longacre. I ordered it on Amazon. $60 shipped.
I find that the filter wants to "walk" up as I turn it. Also, it makes a very slight bend in at the cut point.....so you have to work the filter element out.
That's true for any filter cutter that uses the wheels (like a big pipe cutter). You have to put some pressure on the wheels so they will cut, and that in turn pushes in the metal a little bit while it cuts.
Originally Posted By: oilboy123
Somebody with some guts. Maybe a UOA next time?
The first time was a gut check. I am now on my fifth oil change doing the 1yr/25,000 miles.
Originally Posted By: LargeCarManX2
What type of oil did you use? About 6 K per drain and fill? I did the same on my van and it worked fine. Interesting stuff.
I should have been more specific. I used Amsoil AME 15w-40 for the 27,600 miles too.
I would edit my original post, but since they turn that feature off here (after a certain time has lapsed), I can't. Have yet to understand why some forums do this.
PAblo the cutting wheel has dulled-in order to cut through a standard can, you have to torque it down and the can starts to deform, then the cursing starts............
