One oil filter, 1 year, 2 oil changes, 8k miles, run it or cut it?
eastern NewMexico
I've got the fram synthetic endurance oil filter on the old dodge sludge engine.
I put that oil filter on there June 28th last year. Only took it off to dump the oil out of it last time I changed the oil after 4,000 miles. Well it's been another 3,900 miles.
Am I cutting it or running it for another 4,000 miles?
Don’t take them off when using it for two oil changes. If you break the seal, throw it away. I have run two oil changes per filter for 30+ years. It’s no concern.
Alright the cuts have it. I pulled it off stuck a twig in the anti drain back valve and let it drain for an hour or so in the catch pan then set it on my wood pile. I will cut it open later today.
Ok the 8 thousand mile oil filter does not disappoint. Yous guys was right. I was thinking run it till 12,000 miles. Glad I didn't. Continued here.
