Originally Posted By: Nyogtha
So even at full screen magnification, you can't see the shiny clicker valve in the exploded view between the dome end of the media and the can between 00:35 and 00:45? What do you describe that object as?
You're still obviously not looking at the picture beyond where the little highlight flags are, is that deliberate?
Yes, I see that, and knew that all along. BUT my point is that the video does NOT point to the real bypass valve. The bypass valve is not in the base where the video points to it at time 1:54. You even say the same thing in red above that I'm telling you.
The bypass valve in on the media assembly end cap located at the dome end of the filter, just like it's seen in the photos in the first post of this thread. The video is inaccurate about showing where the bypass valve is really located.
