Unfortunately I don't think that's true, there's a huge variation in filtering quality, even comparing the same manufacturers OEM Vs Aftermarket products.Any name branded air filter will do just fine.
They don't filter well, fit a OEM panel filter, your engine will thank you for it.I hope they are good because they are all I’ve used in my 2015 F-150 since I’ve owned it.
Motorcraft is the OEM?They don't filter well, fit a OEM panel filter, your engine will thank you for it.
I tend to agree with that. The few air filter testing studies I've seen showed various name brand OEM type filters to be in the same rough ballpark as to performance (there's differences, of course, but they were more subtle than substantial), whereas unbranded or sketchy lesser-known brands revealed much lesser performance. I'd leave K&N filters on the shop shelf.Any name branded air filter will do just fine.
Some, Mann aftermarket was very poor in one test I saw, Mann OEM was good but not the best.I tend to agree with that. The few air filter testing studies I've seen showed various name brand OEM type filters to be in the same rough ballpark as to performance (there's differences, of course, but they were more subtle than substantial), whereas unbranded or sketchy lesser-known brands revealed much lesser performance. I'd leave K&N filters on the shop shelf.
I had used an AEM dry filter. I recently removed it. I did an oil analysis and silicon was at 15ppmI went back to the Motorcraft filter. No surprises. I do miss the rigid construction of the K&N though.
The airbox on the mustang kind of has a pinch area that with the K&N I knew without a doubt that the filter was where it should be.
I see filters out there such as the AEM Dryflow that (maybe?) have the build quality of the K&N but with the efficiency of an OEM.
I actually had a fitment issue unless I used the Ford Motorcraft filters, I can't remember what brand gave me the issue but I could never be sure it would seal properly unless I used a Ford filter, it just fit better for whatever reason?
Yea, leave the K&N for a boat, Harley or a modded turbo engine.Just my opinion but I tend to use OEM.
