Hello everyone,
I think it is probably a good time to replace my 2.5L 4 cylinder Jeep Wrangler's air filter. I currently have about 70k miles on my engine and I am using the stock filter at the moment. The air filter was changed around 20k probably then about 10k later I put in a K&N flat drop in. My Si results weren't bad but I currently am using the factory filter I had saved from prior to installing the K&N. I'm going to see if the used oil analysis results are a lot different and probably get something besides the K&N. I always keep an old filter that isn't too bad around for a "beater filter" incase I go offroad where it is very dusty or something.
So i'm looking for suggestions on the air filter. I'm going to get gouged hard on a factory filter probably at least 40 bucks so I wanted to see if there was another choice that was good for me.
I don't really see a lot of dusty driving around here but occasionally I will be offroad with some dust or i'll be out in the field by the combine where there will be significant amounts of material in the air.
Thanks for your time,
Seth
Seth
