Some men often accuse women of being fickle. Here we are on page two about a discussion of washers (again).You can learn quite a bit about used warshers just by looking at them.
They can be, some last for many oil changes. I have to assume you are speaking to metal crush washers and not the single-use plastic or fiber types.Are crush washers deformed, and forever changed after one crush?
Yes, crush washers are simply another sealing method.Is there any actual design that goes into crush washers?
Yes, the difference is in the metallurgy. Silver ones are either aluminum or soft steel and the golden ones are made of copper alloys.Is there a difference between the golden ones and the silver ones?
I had to replace the crush washer on my transmission drain bolt the other day because the crush washer was too thin and no longer sealing; it was 12 years old. Crush washer material spreads out when torque is applied in order to cover the sealing surfaces.If they are not to be reused, can we account for people who never change them and never have failures? On the same note, has anyone ever heard of a crush washer failure?
He looks crushed
Nissan is all happy on the copper ones and they almost kinda thread on to the plug.Never seen the "golden ones" some type of brass?
I have used (and re-used metal types)
Aluminum (fully annealed) - heat and allow to cool at ambient
Copper (fully annealed) - heat and quench immediately
Fiber, single use composite
And they definitely ain't reusable ! You have to unthread them from the drain bolt when you remove the bolt. Anyone that says they re-use them are almost certainly lying.It's obvious that they truly crush when installed.
You cannot resuse the shaped crush washers.I bought a big bag full for every vehicle I own and I change them every time. The copper Nissan ones are unlike any other oil drain washer I've ever seen. It's obvious that they truly crush when installed.
See posts #27 and 31....Anyone that says they re-use them are almost certainly lying.
See the commented I quotedSee posts #27 and 31.
