+1I don't think I've ever replaced one ...
Especially since going to an oil extractor.
Pretty simple to understandI have never understood the point of reusing a crush washer.![]()
I agree with this, but bet Half the people on this thread disagree.We call all kind of soft metal or resilient washers “crush” - whilst only a few actually crush …
And yet it seems like I could go three or four changes with no ill effect, based on responses here.You have never landed on a solid opinion because so many people are ignorant on how they work.
They only crush correctly the first time. (Yes, if you heat, then anneal the flat metal ones, they can be made “as new” but thinner. Those who re-use them typically don’t do this).
They should be changed every time.
The “increased enthusiasm” is the propagation of best practice, not some weird psychological phenomenon.
Those who re-use them are asking for a leak, or overtorquing, just to save 15 cents.
Not an opinion to which you should be paying attention.
It’s fairly low torque and low tech anyway compared to “coined” seals in HPHT applications …I agree with this, but bet Half the people on this thread disagree.
Some of it -- at least on things like Toyota truck diffs -- is about application. Specifically, I'm far more concerned with a drain plug than a fill plug, but to do the job by the book you should use a fresh crush washer on each. I agree, but if I'm low on washers I know which one I'm really worried aboutAnd yet it seems like I could go three or four changes with no ill effect, based on responses here.
Respectfully, because they are reusable, at least to a point. Most of the posters here state they have reused a crusher warsher with no issue.I have never understood the point of reusing a crush washer.![]()
Because it costs about 52 cents each oil change to do it...and no worries about it leaking...52 cents every 7000 miles or so...I replace the crush washer if the one already on is leaking. I don't understand the OCD insanity of replacing something that is working fine.
If it started to leak, you'd see a small tiny puddle and have plenty of time to fix that.
Most of the time you can get them for even cheaper on Aliexpress. That's where got my last 10 pack for my beater Subaru. Perform exactly like OEM.I get a 50 pack of aluminum ones for a few bucks from ebay.
