Crazy in engine piston ring cleaning ideas
I can kinda see how a "piston soak" would be effective at cleaning deposits, but wouldn't it be profoundly more effective if an ultrasonic toothbrush motor (or whatever is small enough to fit) is dropped down in the solvent and allowed to vibrate the piston? Alternatively, and probably far more effective, just use a powerful electric motor to "jiggle" the crankshaft forward and backward by 0.1° or whatever would be best, at ridiculous speeds like 10kHz (or whatever would be survivable and practical within a 1kW standard residential AC power outlet limit).
Second idea is to take some super thin stranded AWM jumper cable wire, spread the strands out slightly in a cone shape so it can still fit, then push it straight down through the spark hole of a TDC piston with the top surface pre-cleaned. When it contacts the piston, the strands will fan out; stop just before they actually touch the cylinder walls. When the other end of the wire is connected to the positive battery terminal, most of the short circuit current will probably flow through the rings and carbon deposits, and it could be possible that the deposits burn like in a self cleaning oven before the battery explodes, the piston cracks, or the copper melts. Honestly, I'm only 80% joking about this idea.
The interesting thing about 'different' ideas is they can often lead towards a new discovery. Even so, done correctly, chemical cleaning is 100% effective. Take a look at 'Easy Off' oven cleaner for it's ability to clean carbon. Berryman's B12 is every bit as good in a combustion chamber. Left long enough, the parts will be spotless.
I've seen something similar to what you describe on TikTok*
It seems a variation on the method H/K dealers use with the pressurized machine/Valvoline solvent
There's also the addition of rocking the engine via the crank bolt
I've had good luck with B12/Kroil and time/gravity, but I could understand for stubborn applications/efficiency, how you'd want to speed it up
It's an interesting theory, for sure 🤔
*I make no claims to the accuracy of this video, it's purely a visual aid
... just use a powerful electric motor to "jiggle" the crankshaft forward and backward by 0.1° or whatever would be best, at ridiculous speeds like 10kHz (or whatever would be survivable and practical within a 1kW standard residential AC power outlet limit). ...
The flywheel might make it difficult to jiggle the crank that fast, especially at the cylinder nearest the flywheel. (That's probably well above the torsional natural frequency of a crankshaft.)
Just hitting redline puts alternating inertial and frictional "forward and backward" forces on the rings at roughly 100Hz.
Good ideas, but the engine crank rotating thing wouldn't work. There's way too much rotational mass to be rotating the crank at that frequency. Also may not be a good idea as you could cause microscopic wear on the various bearings.
The agitation would work only on the exposed part of the cylinder / piston. Those part of the engine don't get too dirty if you have no ignition and fuel problem. The hard part to clean and needed the most is the piston ring area, and agitating everything else doesn't guarantee solvent reaching it faster.
I was thinking periodic cranking manually from the crank bolt would be the best, as the compression and expansion stroke would push the piston ring in and out of its groove and sucking in, pushing out solvent. Ultrasound probably won't do much other than evaporating the solvent faster, like the misting humidifier do to water.
Picture this simple setup. An arm attached to a lever on the harmonic balancer. The other end of the arm is on a pivot pin on a small wheel turned by a reduction gear attached to an electric motor. The distance of the arm from the center of the crank and reduction gear wheel can be varied to adjust throw and frequency. Add a variable speed controller on the electric motor to further control frequency of the crank rocking.
Similar to a steam engine driving a flywheel, except instead of a flywheel turning, you're pushing/pulling a lever attached to the harmonic balancer back and forth.
You can adjust from a slow rock back and forth to a fast vibration.
Not taking credit for designing anything as all of it except the electric motor was done before Archimedes was a baby.
New crazy idea y'all. I don't know how well this would work as a generic solution but for the 1.9L Saturn DOHC and probably most L4/L6s... Pull the front O2 sensor (while engine still hot since that's the only time this can work). Once it cools down, shove a bunch of those blue shop papers towels in the hole.
I guess before that happens we need to make our 4 mini oil vessels. For each cylinder, get some narrow PVC pipes (not sure the exact diameter, will look up later) and in the outer surface, cut some threads in one end so they can be screwed in like spark plugs. Next, cut a hole in the bottom of a small sealable HDPE container and find a way to weld the unthreaded end in it.
Once we have our 4 (or however many) oil catchers and with the crankshaft rotated so each combustion chamber is at at least 25% max volume, add 1/4th of a cylinder volume worth of MMO or even just pure clean Valvoline Restore and Protect into each cylinder through the cap in the HDPE container.
I'm like 75% sure in the the Saturn 1.9L, the intake valves are always closed whenever the piston is within 25% of TDC, but even if it isn't, splashing oil on and around the intake valves isn't going to hurt anything, so that leaves the exhaust.
Pulling the front O2 sensor and shoving shop towels in the hole does two things. First, it protects the O2 sensor from contamination, but more importantly - since we're probably going to be replacing it anyway - it prevents liquid hydrocarbons from flooding the exhaust and blowing up the cat and/or car when it's started.
So you probably know where I'm going with this. Running the starter motor will turn the crankshaft, which will push the pistons to TDC, which would normally cause the soak fluid to blow out of the spark plug holes and/or the exhaust valves. Since we have the exhaust manifold sealed and oil catchers, what should happen is the solvent goes in/out the catchers while some of it drains past the oil ring.
Interesting methods indeed, I think agitation will work best - I personally won’t be putting any pressure on crank bolts though.
And you need… SPEED!
So, here’s my easy, safer way to increase saturation through the rings by agitation.
Secure a multi-tool to the engine where it’s vibrations can be transmitted to the engine. Switch on and let battery run till it’s dead, repeat after a while. This will create tiny waves in the liquid similar to a ultrasonic cleaner.
Just my 2 cents idea 😊
