- Joined
- Aug 3, 2026
- Messages
- 2
I can kinda see how a "piston soak" would be effective at cleaning deposits, but wouldn't it be profoundly more effective if an ultrasonic toothbrush motor (or whatever is small enough to fit) is dropped down in the solvent and allowed to vibrate the piston? Alternatively, and probably far more effective, just use a powerful electric motor to "jiggle" the crankshaft forward and backward by 0.1° or whatever would be best, at ridiculous speeds like 10kHz (or whatever would be survivable and practical within a 1kW standard residential AC power outlet limit).
Second idea is to take some super thin stranded AWM jumper cable wire, spread the strands out slightly in a cone shape so it can still fit, then push it straight down through the spark hole of a TDC piston with the top surface pre-cleaned. When it contacts the piston, the strands will fan out; stop just before they actually touch the cylinder walls. When the other end of the wire is connected to the positive battery terminal, most of the short circuit current will probably flow through the rings and carbon deposits, and it could be possible that the deposits burn like in a self cleaning oven before the battery explodes, the piston cracks, or the copper melts. Honestly, I'm only 80% joking about this idea.
