I hooked up a scope to check on the compression, health of the starter and the new battery and was surprised to find that the cold engine, at 5C ambient temperature, was cranking over at 420rpm, Wasn't expecting it to be this high, especially since the reason for checking was that I thought the starter sounded lazy. Blue trace is the battery voltage and the yellow trace is the starter current, with a peak of 107 amps. The current includes starter relay current and the ignition coil current. Throttle wide open, in clear flood mode.
The cranking sound did not indicate high rpms, that maybe because it is a single cylinder engine and there is only one compression hump every two revs, unlike my truck which has six compression events every two revs.
Googling "CBR300 cranking rpm" produced no results.
