My VW GTI 1.8L Turbo has a hairline crack in the top of the dipstick. What this has shown to me is that enough crankcase pressure builds up to force a little oil through the crack. Some modified versions of this engine have even blown their dipsticks out of the tube during high boost...at least I don't have that going on.
It would be good to lessen that pressure by evacuating it by a route in addition to the usual PCV system, which clearly isn't "keeping up" with the pressure buildup. That pressure is from chemically nasty gas/solids which degrades the oil.
So a thought occurred to me. Take out the dipstick and replace it with a hose with a one-way check valve that leads to a catch can and finished off with a high efficiency miniature air filter. This would possibly allow pressure to escape while the check valve prevents sucking outside air in during crankcase vacuum and the air filter would filter outside air that does squirm past the valve when closed. The catch can would condense some of the oil/water mist so I don't turn my engine bay into a stinky oily mess.
It may require some overall design tweaking to work well. I know this is NOT needed. I just think it would be a neat project. Have any of you heard of any similar setups?
