I have a small block chevy on my 1983 El Camino that has 366,000 miles on it. I remember about a year ago I needed to replace my valve cover breather, a neighbor gave me a K&N breather that was brand new that he no longer needed, it was still in the box.
On the other valve cover I had a new PCV, my thought was that this K&N breather would allow more fresh air in as well as letting some pressure escape easier since it was more free flowing.
It did not work out to well, I had oil that was leaking out the rear main seal, maybe there was to much pressure, so I went and got a chrome breather with the foam inside and everything was fine, no leaks.
I had thought about a breather on both valve covers, of course I would not have a PCV, and I figured I would have oily residue inside the engine and on my windshield.
Someone told me that it was better to have the PCV Valve on there because it acts like a suction and pulls the harmul fumes out of the crankcase, whereas a breather just vents it out which is not that good.
Moroso makes a Crankcase Evacuation System that has 2 breathers and runs a hose on each 1 down to your exhaust pipe, I have read that this is for drag racing and even though I have a free flowing dual exhaust I have read that if it is not free flowing enough this Moroso unit will not work, something with the check valve not opening up.
Any thoughts on why that K&N Breather did not work would be apprecaited.
