While fiddling with my catch can setup I discovered that:
1. I have positive pressure in the crank case at any RPM. When I remove a dipstick, the gases (oil mist) blow from there. The same is true for the oil filler cap.
But:
2. There is a good flow through PCV valve, smaller at idle, increases with RPM.
and
3. Here's the trick: there is suction on the fresh air PCV intake at any RPM without load. The crankcase gases do not go through fresh air tube at all.
My engine is DOHC with "traditional" PCV setup: Fresh air tube goes from before the throttle valve into the valve cover. PCV tube goes from after the throttle valve into the valve cover, may be three inches apart from the fresh air tube.
PCV valve is screwed into the valve cover and has a solid, all-metal construction and it gets cleaned at every OCI with acetone and TB cleaner. I'm sure it is not clogged at all. If it was, there would be very little flow in PCV tube...
The engine has 60k easy miles on it, never abused, 3-6k miles OCI with mostly synthetic oil.
Is that normal to have positive crankcase pressure? Should it not be close to atmospheric, or even negative?
Please help me as my stress level increases every minute. Do I need counseling?
But:
and
