Craftsman Oil Port Ratchet rebuild
North Carolina
My old 1/2 ratchet started skipping here and there, so i bought a rebuild kit for it.
I will clean it well, but should i use superlube syn grease in it, or oil? @Trav has posted about atf dunks.
Thoughts?
Either way it will probably outlast me after a rebuild.
Clean it up, put it back together, and oil it = rebuild. A drop or two of oil (your choice) once a month on a ratchet that gets used daily.
I have used this assembly lube based upon suggestions from the "old wise mechanic" that used to rebuild Craftsman ratchets on the spot when the Sears & Roebuck Brick and Mortar stores were thriving in the '90s and early 2000s.
