SR77
thanks again for the replies!
ok heres what i did. Took the carb off cleaned it out completly, bought a rebuild kit for it and replaced the needle and seat, gaskets etc. The gas tank was cleaned out and it has a new fuel line on it. I bought a new spark plug for it too and gapped it per the manual and got a new air filter. Cleaned the engine and put it all back together. started it up in one pull and ran great for about 20 mins and I thought it was fixed. Then it started to sputter again and died!!!!! And I could not get it started. Pulled the plug to check for spark and looked like there was some spark.
So here is my question for you guys, can a bad coil still spark but maybe the spark is weak or intermitten? I am running outta options here. I can't figure out why it dies out. I have cleaned everything and replaced all the maintenance items including rebuilding the carb and it still continues to not run after a while. If its not a bad coil I am lost! thanks again for you help. I am close to going shopping for a new tractor!!!!!
