Originally Posted By: stephen9666
Originally Posted By: Chadwilliam1
there is no spring its called a floating Pawl.
I've disassembled these ratchets multiple times, but I don't have one in front of me right now. But, I'm about 99% sure I remember how they go together.
There is a spring under the pawl that you just can't see in the pic I took. If I disassembled the mechanism, you could see it. There is a small spring-loaded pin under the pawl that pushes the pawl up towards the gear. The spring is under that pin. While the pawl is called "floating," that doesn't mean it isn't spring loaded.
That is how the standard Craftsman ratchets are, anyway. A spring pushes on a ball bearing which in turn pushes on the pawl.
