Originally Posted By: d00df00d
Originally Posted By: rudolphna
Until you try to drive in the winter, because no driver can react to locked up wheels as fast as the computer can, and NO DRIVER can lock and unlock the brakes as fast as a good ABS system can.
Not to mention, when most people see a puppy, or a deer or another car cross in front of them when they weren't expecting it... Their first reaction is going to be to slam on the brakes. Without ABS, this will cause all 4 tires to lockup, and you lose steering completely, potentially flipping the car in the process. With ABS, the wheels will still turn, and you may be able to steer around said obstacle.
The operative word here is "good."
A bad ABS system is still often better than nothing, but IMO the benefit is small enough that you still need to be a decent driver to work with it... at which point you almost might as well remove the ABS system and save the weight.
Plus, I have a feeling
BuickGN has a good deal more experience than you do in low-traction conditions.
Probably. But you find me a driver in which the scenario I described will not result in a panic braking. The ABS on my cavalier isn't that great, but without it I definitely would have been in an accident this past winter. I pulled into the school parking lot, which is a slight downslope. Doing, 10ish mph, road looked clear. Vehicles up ahead waiting in line.... put brakes on to stop. Kept sliding, ABS kicked in and I managed to steer to the side. Black ice, completely invisble on the road surface they used.
