I'm having some detonation/preignition issues with my '01 Grand Marquis, and have yet to pinpoint the issue.
Driving along, there's no detonation, but as soon as the transmission upshifts, there's detonation under light throttle unless I depress the gas further. If I'm going uphill, it happens again at the same throttle position.
The first thing I did was check and clean my MAF sensor, which reads 0.69V (should be in the 0.6V - 0.75V range), but that did not help. If I'm running 91 RON (87 AKI), the issue is much more noticeable. Move up to 95 RON (91 AKI), and it doesn't happen as much, unless you depress the a little further in the same gear. Move up to 98 RON (94 AKI), and the issue disappears completely.
There are no codes stored in the PCM. I'm just wondering if the time has come to replace the EGR valve. It's still on the factory one at almost 293,000 km (183, 125 miles). Thanks!
