Hi everyone,
I recently cleaned up a set of OEM Nissan wheels for my Maxima that I had saved from a previous Maxima. I was originally going to have the wheels reconditioned, but for the $650.00 cost I would rather clean them myself.
The outside face of the wheels cleaned up nicely from the heavily baked on brake dust. They are not perfect by any stretch of the imagination, but they look very presentable.
The question I have is related to some corrosion on the inside of the wheel. There are some areas that have developed corrosion and I am not sure if it's an issue that needs to be addressed or will it be fine leaving it alone. The areas that have developed corrosion will not be visible once the wheels are installed on the car, so aesthetically its not an issue.
Will leaving the corrosion "untreated" compromise the structural integrity of the wheel?
Would quickly sanding the areas and spraying them with silver spray paint be useful?
I also noticed a bit of corrosion in the bead area on one of the wheels, but I assume that has been there for a very long time and I never had any air leaking from the tires.
Thank you everyone!
Thank you everyone!
