Corolla/ prizm timing belt change
mass
i getting ready to change the timing belt in my sister's 97 Geo Prizm. What else is needed/recommended to change while i'm in there? any seals or pulleys that need changing? i have the belt and tensioner. i'll change the water pump too while i have it off.
i'll pick up a shop manual too
i've down this job an yanmars just never a car
thanks
Make sure to measure the free length of the spring in the tensioner.
I dunno what the cam adjuster seal is, don't know that it relates to the Corolla. Since you'll have the valve cover off, might as well check and adjust the valves too. That's a fun job for the first time on a shim over bucket valvetrain! Also, don't forget to add RTV to the areas it lists in the repair manual when you put the valve cover back on. If you don't, you'll get a fountain.
