What happened to the one in the Alero?
The coolant tanks on Boxsters can leak as they age. I've replaced my once on my 2000 Boxster. It's a PITA to get to it, so I'll just keep an eye on it and deal with it when needed but probably won't let it go more than say, 15 years. But on most other cars, I don't replace on a set schedule, but won't hesitate replacing it if it shows any signs of issues, especially if it's a pressurized tank. If it's an older-style overflow type like on my 2020 Tacoma, I'm not really concerned since if it leaks, it'll simply make a mess and not screw up the coolant system.Just replaced the degas coolant reservoir on my elderly Saab. The hose nipples are known to crack and blow coolant. Some reservoirs are prone to leak at the seam where the halves are joined. I prefer to be proactive.
Do any of you replace yours as a routine maintenance item?
Thanks for posting that suggestion. When the time comes to clean the reservoir, I'll certainly give it a try.The only maintenance I do to the reservoir is rinse/clean the inside (as needed) when replacing the coolant.
- Pour in some uncooked rice (ex. Kokuho Rose).
- Fill reservoir with water.
- Shake the reservoir, allow the rice to scrub the inside.
- Pour out the liquid - repeat 5-7 as needed.
