Originally Posted By: Artem
Why do more maintenance then necessary? It's no better then changing the oil @ 3k
Preventative maintenance is possibly the best thing you could do for any machinery.
If you look at other forum topics, you will note that many of BITOGers do this for all fluids (PSF, brake fluid, clutch fluid, ATF, MTF, gear lube, etc.).
I don't think suggesting doing a partial removal of antifreeze from the cooling system as a completion of the coolant change. A drain and refill only removes a percentage, which require a few drain/refills over time to remove almost all of the fluid, statistically speaking.
The fluid in the OP vehicle is 4 years old, at least, with a 5 year change requirement. It's better to start planning now to complete this exchange and the OP can choose to take this advice how he pleases, either with doing drain/refills or waiting to do a complete exchange.
Oil changes at 3k miles would benefit many, depending on their driving habits and vehicle usage. If I did 3k mile changes on my truck, that would be 8-12 months time wise. There is not a clear, singe defined answer on these topics.
