Is it ok to use mopar coolant in my mazda?
Fort Drum N.Y
I have some 5 year 150,000 mile mopar coolant left over. I believe it is a hoat coolant. Is coolant really all that much different I couldn't use It? I'm not just adding coolant. I am doing a flush.
Cincinnati, OH, USA
Mazda is generally a P-HOAT, is the Mopar GO-5 (red), or is it the funky Fiat purple color (which is more like Dexcool)? I'm not sure I would risk either of the Mopar coolants in a Mazda FL-22 application, Zerex Asian Vehicle and others have really come down in price.
Micahmcmeen
Fort Drum N.Y
It is a bright pink.
Micahmcmeen
Fort Drum N.Y
Reads like leftover is Mopar G-05, low silicate OAT (Hoat). With a complete flush, it should be ok in the Mazda. The Mazda specs Phoat, phosphated OAT. Knowing that, if comfortable using up G-05 over staying with spec, your ride, your call.
What's the real difference between the 2?
The Old North State
The difference is Mopar uses silicates, Mazda uses Phosphate (no silicates). Asian vehicle manufacturers prefer a no silicate formula AF, using phosphate instead.
YYC
I've used Zerex G-05 (aka Chrysler HOAT) in a Mazda3 that came from the factory with the dark green P-OAT with no issues. I wouldn't worry about mixing a coolant that has silicates with one that has phosphate as the newest generation of euro coolants like VW G12 Evo do exactly that.
