Hi.
I already posted about similar issue in previous thread and got some great advices from you, but now i have more specific request.
As far as i understand, optimal ignition timing should vary depending on the rpm, load and fuel quality.
In my case, since it is distributor based mechanical ignition timing, it is static.
There is no marking on the distributor (or on the engine) which suggest the default position.
So i am not sure what is the default position. But even if there was, there should be different position settings for different fuel octanes/ Shouldn't be ?
Anyway, Currently my distributor is on X position. The performance is very nice. Even better than it should be. Because some people who have the same model car had some test drive and they were surprised.
I am generally driving in city. And it feels nice, without any problem. But, when i am going to my village, where i have to climb hills, with extra 4 people in the car, and some heavy bags, engine starts detonting. (the load is relatively high, since car's weight is only 960Kg)
Well, i can easily prevent this by retarting the ignition, but in this case car's performance will degrade significantly. I almost feel as if it is 20% power drop.
So my question is that, if i convert distributor ignition into electronic ignition system, where knock sensor will also be involved, Would new ignition system automatically arrange the timing for the best performance while preventing the detonation under extreme loads ?
Car has G15MF GM Engine, while there is similar model, A15SMS with electronic ignition and knock sensor. Conversion is not very difficult. But wlll i get the most optimal ignition timing in this case ?
Anyway, this is not a critical problem. But it would be nice if i can do something about this. I like to make some modifications in the car in my free time. So if you have some experience of convertiong distributor ignition to electronic, please share your experience
REgards
REgards
