So some engines (SBF's included) exhibit drain off with synthetic. That is the residual oil film gets thinner over time. Never w/o an oil film, but on cold start there is not as much cushion. Most synthetics have lower surface tension than refined conventional oil due to their more consistent chemical makeup.
This lower surface tension is one of the contributing factors in their being able to make the 0W-40 spread. But, that means they are less likely to maintain a robust capillary fill. Conventional oils like Delo 400 will maintain capillary fill very well.
So that means you'll hear more clicking and clacking on cold start after sitting for a while (weeks >). Has happened on a number of SBF's I have built. It also depends on clearances used to build the engine....
I'd run a quality conventional oil and the best filter I could get. Not for the media, but for the anti-drain-back-valve. Good filter and good oil will mean quiet starts and a long lived motor
Wix (Napa Gold), Baldwin, Fram Ultra, etc. Maybe Chevron Delo 400 15w30 SD (severe duty). It ain't cheap, but the mostly conventional base and narrow spread means good residual film on cold start and it's tough enough to go a few years w/o change.
I have run Delo 400 15w40 LE for up to 5 years in seldom run ranch trucks. No issues at all. As long as the carb is in decent shape and not pouring raw fuel into the motor on cold start (?), it'll be fine. Just make sure it gets up to temp and stays there for a while when you run it. No need for annual changes on you low mileage. If you have concerns, get a used oil analysis at year two and see where you are at. Should be fine. If used oil analysis comes back good, just leave it in there
