Originally Posted by OVERKILL
Originally Posted by StevieC
Oh also... Check out the Engine Tear Down pictures here of the Chevy van that did a million miles and you can see heavy varnish in the engine. How was varnish a bad thing here?
http://www.syntheticwarehouse.com/brochures/million_mile_van.pdf (PAGE 3)
The varnish would have been from the long OCI's he ran, and that's obviously a design that is reasonably tolerant of varnish. One has to consider though that this is almost 1,000,000 miles of accumulation. What do you think it looked like at 150,000 miles? Obviously the mileage was outpacing the condition and something else was bound to fail before the deposits had a significant impact. And for the mileage? There really isn't that much build up, that's quite frankly, impressive. Would have been nice to see compression numbers from it though, and shots of the pistons to see how free the rings were.
What about the varnish in your beloved Mobil-1 oil that did the 20,000 mile run? Where is that engine failing?
Do you mean their promo video? Have to be more specific. My experience is M1 is good at keeping engines clean when used on a reasonable OCI, but I've never run it anywhere near that long and if there was varnish in the 20,000 mile run you speak of, then yeah, that's a good reason as to why I would avoid it. You saw my M5 head shot, I generally, like I'm sure you do, despite this conversation, prefer my engine to stay looking like that. Which was also on M1
Look at this piston from the Schaeffers engine tear down. Look how dirty it is and no stuck rings... ?!?
The oil control rings don't look too hot
Those are the ones that stick first, and they look stuck in that picture.
This "pomp piece" from Mobil, which is for 500,000 miles of dyno time (yeah, I know), shows excellent cleanliness:
This 120,000 mile taxi (pomp piece) engine teardown also shows excellent cleanliness and you'll note one of the key things they are looking for is varnish:
And some pics from the above vid of the pistons and the rings, which are clearly free, including the oil control rings. Pistons are also quite clean:
Overkill,
If you look at the Mobil 1 video where they show the engine torn down after 20K miles there is quite the varnish there and M1 doesn't seem concerned with it, so much so that they are making the claim that it's fine for 20K miles. How many of these 20K runs with this amount of varnish after one run would there be. Surely a huge company like M1 that makes great products would be concerned but they don't seem to be.
As for the Schaeffers engine if you watch that video you will see him moving the rings back and forth in his hand on that piston I provided the picture of and it looks fine. There is heavy build-up on that piston as well as varnish at particular shots and they don't seem concerned with it either. I'm not saying I would accept this amount because you know I'm OCD when it comes to this sort of stuff in my own engine but my point is that they aren't concerned with it so clearly it supports my claim that varnish is harmless where the engine isn't overly sensitive to it.
As for last night and some of what you were saying, let me be clear. The engines that had varnish where the engine didn't have issue with it because they weren't tolerant of it ran to the end of their service lives fine. That the ultimate goal. The engine lives to the life expectancy of the user. Who cares if it had a lot of varnish or little varnish. The engine made it and it did so without the performance being impacted to the point where a repair was required or setting a CEL or affecting the performance as measured by the driving that is encountered.
I'm sorry you are having such a hard time admitting that varnish isn't a problem but it isn't in the vast majority of engines that it occurs in. It just isn't. Other folks here confirm this so it's not be being biased to what I've seen. And in the case of the Million Mile Chevy where it was torn down and you do see heavy varnish it didn't affect the wear on that engine as measured and also didn't affect it from running perfectly as stated in the article and it was torn apart by a 3rd party not even the company that makes the oil.
So I say again in summary if varnish is such a problem why aren't Amsoil, M1 and Scaheffers concerned based on their own engine tear-downs where it exists? BECAUSE IT'S A NON-ISSUE FOR THE VAST MAJORITY OF ENGINES WHERE IS OCCURS and it's due to poor engine design in the ones that seem to have a problem with it OR ELSE every engine out there that ends up with varnish (and there is a ton of them) would be experiencing issues and it would have forced OE's and Oil manufacturers to scramble for a solution quickly like with LSPI.
I'm done now because we are going in circles and I can't state it any more than I have. I also have quite a few conference calls today and then late calls with Japan tonight so I wouldn't be able to get back to this until the weekend if I wanted to anyway.
Have a good day.
