Originally Posted by Trav
That is on a 5K synthetic OCI. People here went nuts when I first posted this issue with some Honda engines almost 10 years ago then a few years later more and more started showing up.
Toyota 3.0 had bad problems, so bad in fact Toyota had a TSB requiring 3K OCI with synthetic oil. Just because you don't see the varnish on the top end it doesn't mean the piston rings are not getting sticky so you cant make that statement either unless you are doing a compression test on every engine.
I did a low mile R32 with a spotless top end, it ran well but has universally lower compression than spec, an overnight piston soak brought it right back to spec and it stayed there with a shortened OCI.
Listen, lets not make this into something it's not. I posted the top end pictures as an example. Did I say not to check the bottom end? Did I say that it couldn't have issues for the pistons and their rings? No I didn't. I posted a lightly varnished engine which is NORMAL to see in A LOT of engines particularly Euro ones like BMW and it's perfectly fine with no hindrance to their operation. Are there some engines that are poor designs that can suffer from mild amounts of varnish? YES and I said that to TIG. BUT IT'S NOT THE NORM and quit trying to make a mountain out of nothing because you have your knickers in a knot over some of my posts you don't happen to agree with.
It's up to the OP to decide what is best for him and what may or may not be an issue. He shouldn't panic about some light amount of varnish simply because of a few engines with poor designs suffered from it when the majority do not suffer from it. The GM 8-cylinders are notorious for having heavier varnish resembling more like the first picture you posted than the pictures I posted and they go along just fine their whole lives. 0 issues.
Look at the right head
