If you view this thread as a troll, then why have you posted on it twice?My point is sarcastic. You have gone far off the manufacturer recommendations. And not just with a slightly thinner or thicker oil. You have not shared your motivations or theories with us. There are some instances, I suppose, that folks might choose conventional over synthetic, but this ain’t one. I am almost inclined to view this thread as a troll
I suggested Delvac 0w40 because it’s a PAO instead of a group 3 which may “synthetics” are. It’s also blended with the best additive package and viscosity modifier Oronite has, therefore is shear stable so it stays in grade over the drain interval. HDEO 0w40s have to jump through more hoops than the other grades to certify that they are shear stable to prevent very expensive equipment from breaking down. I’ve used it in similar applications, 0w40 Delvac starts out thicker than many other 0w40s, is available at Canadian Tire where you obviously shop and I’ve performed UOAs running way past OLM with it.
Edit: oops, Infineum, Oronite is Chevron.Havoline rolled out a 0w40 with all the Euro certifications last year.
