Originally Posted by Ponchinizo
That Valvoline Restore oil sure looks interesting! I just might have to give that a try,
should I run a more robust filter if and when I use it? I am currently using the Toyota 04512-YZZA6.
Yes, maybe switch to a Fram Ultra. It can hold more than most other oil filters before clogging, and is wire-backed to take the chunk-abuse.
I would change the first oil filter early, at 1,000 miles (like Lignums below did), and then at another 3,000 miles accumulated, for a total of 4,000 miles on the oil change, maximum.
Here is an oil filter showing the junk liberated from inside the engine using Valvoline Premium Blue Restore 10w30:
https://www.bobistheoilguy.com/foru...xg3506-valvoline-blue-restore-1000-miles
Black pistons are a problem just about everywhere, although they don't always result in stuck rings & oil consumption of course.
Some pictures:
Originally Posted by oil_film_movies
Valvoline Premium Blue Restore could be a good answer for the infamous Toyota-Scion oil usage issue, when the piston rings are sticking. Then people might not have to tear the bottom half apart and drill more/bigger piston holes.
... and when using just about any oil, as in the piston below after 20,000 miles using Mobil 1 Annual Protection:
I'll be using VPBR (which does not stand for Valvoline Pabst Blue Ribbon, BTW....) every 75,000 miles just to get rid of piston carbon, summer-fill only since this VPBR is a little thick, not too bad though.
Originally Posted by Lignums
Originally Posted by WellOiled
So, it looks like this oil and cleanup procedure worked for you?Would you recommend it?
So far, just by decreased oil consumption, the crud already visible on the filter media, yes I would recommend it. Given the condition of each individual motor of course. I do not believe that this oil is a sludge remover, there was no evidence in the filter, or my drain pan of any sludgey substance. The only evidence of any cleaning was in the filter media, in the form of carbon particles. Each motor will have its individual issues. Mine was 99% related to carboned up rings, from my own research and the GM mechanic. For those motors that have carbon buildup issues I am positive it will help in that area.
