https://youtu.be/oBcYKKDybqk
Fast forward to about 11:28 for info on the now infamous 2018+ tick and looser clearances on this line of engines. Mustangs get 10 quarts of 20 grade and f150's get 9 quarts. Would a thicker oil help with this engine that seems to have been built on the loose side from the factory? Would a 30 or even a 40 grade help to alleviate some of these looser tolerances?
I know that most tend to have a bit of a consumption issue when new. And most seem to have a tick, some worst then others. They also seem to be a little harder on oil. Most uoa's that I've looked at ended up on the lower end of the 20 grade spectrum.
Thoughts?
Thoughts?
