Okay, I've been spending some OCD time online and on the phone and I can't quite get a straight answer to my question about how a Royal Purple 0w40 and a single SAE 40 functions at a given temperature. So far I have been told that when the outdoor temperature is over 60 degrees and the 0w40 is hot it is a 40 and that the SAE 40 is a 40 when the engine is cold or hot. I have also been told that engine wear would be greater on start up with the SAE 40. Now if the 0w40 is a 40 when the engine is hot, and you shut it off then start it again are you not starting the engine with a 40 weight oil just the same as the SAE 40 when it is cold or hot?
