Condensation drops on HVAC vents
Near the beach in Delaware
Daughter in NC has drops of water on the metal HVAC vents. I assume vent metal is cold and water condensing. RH inside is 55%.
I am thinking the only solution is to add a dehumidifier to the HVAC and dehumidify more than just when the AC is actually running.
Will the vent metal or screws rust over time?
Yes they will rust over time .
dehumidifier will definitely help.
in a hot humid climate I would insulate all duct work if possible.
Ideal humidity is 30 to 50 percent I suspect at certain point of the house the humidity is higher than 55%
