Hi there,
This is lengthy but I need a proper diagnosis.
Problem: This A/C runs upwards of 12 hours a day even when it's only in the 80's outside and the thermostat is set to 73. It can be 75 outside and I'll have the Nest set to 72 and it will take hours to drop 3 degrees. It doesn't dehumidify at all. I bought a dehumidifier that removes about 8 gallons a day even with the air conditioner running all day. Humidity is about 68% when the a/c is on and the dehumidifier is off. This system was completely discharged and recharged to the superheat specs by a certified tech that works for my apartment complex.
Apartment specs: The building is two stories, I live on the second floor. This is a "pull-down" system and has one return in the middle of the apartment. it's 1100 square feet with 3 windows and a standard slider for patio entrance. The windows are new and well sealed.
More notes: The system seems to have a hard time getting enough air flow into the supply. The indoor part of the system is in a small closet with the hot water tank. The blower is trying to pull so much air it literally sucks the door closed when it's on. So I don't think the supply vent provides enough.
I have a 3rd Gen Nest installed. Usage lately is as follows (sorry so big). Weather during this period ranged from 60's to mid 90's.:
Equipment:
Condenser: http://www.goodmanmfg.com/docs/librariesprovider6/default-document-library/ss-gsc13.pdf?sfvrsn=0
A-Coil: http://www.goodmanmfg.com/docs/librariesprovider6/default-document-library/ss-gcoil.pdf?sfvrsn=0
Return:
Tech specs: The supply line from the condenser reads at about 56 degrees right before it enters the a-coil. The nearest vent is always at 12 degrees warmer. So it's losing 12 degrees of coolness in about 3 feet. The duct system is in the ceiling, which is the technical attic for the building. This is where I think it picks up a ton of heat. The return/supply split is never greater than about 12-14 degrees.
I think this system runs way too long and does a horrible job of dehumidifying. Am I wrong?
Thanks
Equipment:
Return:
Thanks
