I know this is a little off-topic since it's not directly oil related but...
I'm looking into buying a compressor and wanted to get some advice. My criteria are small and, of course, the cheaper the better. The impetus for buying it is an upcoming wood fence rebuild which I'd use a framing nailer to help with. Air would also be nice to blow things off/out and fill tires. If I had a compressor, I might on occasion find use for an impact wrench. This compressor will likely sit for weeks or even months without being used.
That being said, I've been looking at small, electric pancake compressors mainly designed for brad and nail gun usage. Most of these are oil-less which I understand aren't as reliable and not designed for long duty cycles. They also tend to be loud from what I hear.
I found the Porter Cable model CPF23400P...
http://www.porter-cable.com/index.asp?e=547&p=2582
that can be had for just over $200 and is capable of deliverying 5.3 SCFM at 90 PSI. I think this might be enough air to power a small impact wrench here and there. The size is right and the price is about what I was looking to spend.
Does this sound like a decent tool for what I'd use it for?
I'm new to compressors... if the pump is oil-less, do you then oil the tools indvidually?
Thanks,
Matt
Thanks,
Matt
