Getting close to time to change my ATF in the 8L45 in my GMC Canyon. What is the best way to swap as close to 100% of the fluid out without going to the dealer? A pan drop and filter change only gets about 50-60% of the fluid.
Once upon a time on an older vehicle I didn’t care too much about I hooked a clear hose to the outlet line that went to the radiator. I started the engine and at the first sign of air bubbles (trans pump had sucked the pan almost dry) I shut the engine off and added the same amount of fluid that got pumped out back into the transmission. I did this 3-4 times and 100% of the fluid was changed over to brand new stuff.
This still a good idea? Or an I just better off draining the fluid out of the pan a few times? Thanks!
