Quote
...But you can easily go to Walmart and get a Fram PH7317 which is the Honda A02
Fram is also the OE supplier to Subaru but doesn't use their high-spec bypass in their aftermarket filter....
Both the Honda A02 and the Suby filters are made by Fram, to their respective company specs. One ISO 4548 -12 test showed the A02 to be significantly less efficient than an equivalent orange can. It's been some years now, but a Fram engineer confirmed the Honda A02 has lower efficiency. And iirc the former Fram rep said similar here. If I had to speculate, I'd say the Suby filter closer to the A02 efficiency than the PH7317. The 22 psi bypass used on the Suby filter(s) made by Fram to Suby spec.
It is true that equivalent application Fram and other brands use a lower bypass spec, likely since in addition to Subaru they are used in many other applications.
